Twisted Pair Cables
ptc-1852440
Twisted Pair Cables
Hi All, Within Pro Engineer Wildfire 5.0 is it possible the produce Twisted Pair Cables within Pro Cabling. If it is possible, what is the best way of acheiving this? If, not is there a work around. Thanks in advanced Paul
Haven't used cabling, but I had to 2 a pair of twisted pairs, twisted around themselves, and I did it with variable section sweeps. Turned out very cool. Could have fudged it, but wanted to challenge myself.
DavidButz
(To:DELETEME)
Quick example of what CM is talking about; but if you are doing extensive cable routing it's probably not a practical technique.
Hi CM and David, Thanks for youre reply, yes this would be a good work around If you was only producing a couple of cables. Unfortunately, the customer is routing cables all day long. Do you know If this exists within Pro Cabling?
