UNLINK IMPORTED FEATURE
MB_10508968
I have a lot of "imported feature" files that seem to slow the parent assembly when opening, rotating and zooming the view.
I believe this is related to the fact that CREO 9.0 tries to access the local path T:\DEFINITIVI\... linked to the imported 3D model: is there a way to unlink the 3D model from the original file path?
Thank you
pausob
(To:MB_10508968)
Out of curiosity, how large are your files?  The numbers in brackets suggest 1GB of data!?
Anyway, maybe try the "Make Independent" function in this menu to break the link:
, or uncheck the "Auto Check Status on Retrieve" ?
pausob
(To:MB_10508968)
remy
(To:MB_10508968)
Hi you are experiencing graphics slowdown with imported geometry.
How did you come to the conclusion that this related to the referenced model ?
What's the original file format and how big is it ?
