Unable to draw or open the drawings in Creo 4 student edition
Rohith
3-Newcomer
Hello Everyone,
I am unable to draw any drawings in the main window and also I could not able to open the existing drawings.
When I open the new doc/page, it's completely blank. I could not able to see any coordinates.
I have changed view settings to unhide. But the same problem persists.
if I open any drawing, I can see every feature that what I have used but no drawing.
You can see in the screenshot.
 Thanks and Regards
Rohith
7 REPLIES 7
MartinHanak
(To:Rohith)
no solid geometry is displayed in opened prt0002 part. The possible reason of this problem could be graphic drivers.
1.] put following option into config.pro file and test Creo
graphics  win32_gdi
2.] update graphic card drivers, if it is possible.
Martin Hanák
Hi Martin,
Thanks for your suggestion.
I have reinstalled the graphics driver. It is working fine.
Thanks and Regards
Rohith
MartinHanak
(To:Rohith)
Just forget to inform you that setting graphics  win32_gdi option is temporary solution. It is necessary to remove the option, if updating graphic drivers resolves the problem.
Martin Hanák
Hi Martin,
Thank you..
I have not changed the settings of graphics win32_gdi. Instead, I have directly updated my graphics driver.
it's working fine.
Rohith
kdirth
(To:Rohith)
Have you unhid all of the layers in the layer tree?
Rohith
3-Newcomer
(To:kdirth)
Yes...I unhide all the layers
Mahesh_Sharma
22-Sapphire I
(To:Rohith)
You may mark Martin's valuable information as solution of the post.
