Hello everyone,
I have a problem with the hole notes that IFX creates for dowel pin. Notes mentioned a threaded hole as in attachment while it should be a smooth drilled hole with tolerance.
Could you please advise me on how to manage this issue ?
I think the information for the hole is shown correctly in general, but it is possible to customize the hole note.
For more details follow this link:
https://community.ptc.com/t5/Creo-Modeling-Questions/CALLOUT-FORMAT-in-hol-files/m-p/153980
Or directly look to the PDF from PTC.
Oli
Hi Oliver,
Thanks a lot for your quick reply, I will look at it
