Unbend sheet metal
T_F
Unbend sheet metal
I've a part that I'm not able to unbend it.
The forming in the bend is giving some concerns. any idea?
Can you help me?
tbraxton
(To:T_F)
An example part ( Creo 7) of flat of form across bend. Flat pattern is included in the part.
Involute Development, LLC
Consulting Engineers
9 REPLIES 9
tbraxton
(To:T_F)
The part you posted in not a sheet metal part, so the unbend and flatten are not available for use for this part. The geometry is brought in from a copy geometry feature. Look at the parent model for the copy geom and if it was created as a sheet metal part you can try to flatten that model.
T_F
(To:tbraxton)
The part was an imported model from other software
tbraxton
(To:T_F)
Have you tried flatten quilt functionality? The geometry looks to be composed of ruled surfaces so it should work.
https://www.ptc.com/en/support/article/CS107749
KenFarley
(To:T_F)
That part looks like it is initially bent in the "normal" manner, but then crimped or stamped to put the strengthening feature in. Does sheetmetal handle that kind of deformation? I don't know that it would...
T_F
(To:KenFarley)
Exactly... I tried to unbend it, I had to remove the geometry of the form in the bottom bend.
I tried also to recognise that geometry as form. But no way to unbend
tbraxton
(To:T_F)
Perhaps if you create the geometry using two basic forms it may work. One a corner gusset (#1). An example of such a gusset is shown in the second second picture. Such a gusset will flatten using the flatten form function, so crossing a bend with the form is not an issue.
T_F
(To:tbraxton)
I've followed your suggestion, but still no able to unbend it.
Can you share the part that you shown in the second image?
tbraxton
(To:T_F)
T_F
(To:tbraxton)
The unbend command doesn't work well with some types of stamping forms. In this particular case, it doesn't work also.
But as you suggest the flat pattern works!
