Unverified family tree in creo 2.0
vishalprajapati
11-Garnet
Hello everyone,
I have made family table in which i verify one model in family tree after i changed the dimension then it shows unverified,it restrict to save the file.
anyone have any idea?
Vishal Prajapati
If you change a dimension that affects all the other instances, then all the other instances need to be verified. You can do this from the family table menu or by opening and regenerating every instance separately.
I believe there is no 'auto-verify.'
Family tables are typically used for parts which don't change, such as fasteners. If there was an 'auto-verify' Creo would have to regenerate the full set of instance for any change you made, a large waste of time.
As long as you are developing a model associated with a family table, get used to opening the generic and using Verify. You can make as many changes as you like and then Verify only once before saving it.
6 REPLIES 6
Did you verify all the models in the family table?
Thank you for your reply,
The problem is that i have verify model in family table but when i changed the dimension of the model and save the assembly at that time it resist to save the file. open again model/model family table then it shows unverified.
How to auto verify family table during changed the dimension.
Vishal Prajapati
Is this a part family table or an assembly family table?
Do you have any dimensions in the assembly driving values in a component family table?
What build of Creo 2.0 are you on?
Thank You
When you are using Creo with PDM, the "verify_on_save_by_default" config.pro option that if set to Yes, it gives you an option to verify unverified family table upon Save.
