User notify from Relation in drawing
Ketan_Lalcheta
I am writing a relation into drawing file. Based on two different input values, one calculation is to be done.
If calculated values comes as negative, I would like to notify user about same. Could anyone help me on how to notify user from relation?
Thanks in advance!
Ketan
Hello Ketan Lalcheta
got two ideas on my mind. But it´s reached in modeling space and not in drawing space.
1. Show parameter value flat to sreen
2. Edit Proprogram to color part (just for inspiration)
If parameter value is lees than 0 ---> color part red
If parameter value is greater than 0 ---> color part green
Please see attached file. l have achiev something similar for you. (very simply example)
In drawing space? The simpliest solution l know is show desired parameter on your drawing. Everyone got the actual value on eyes.
Hope you will get some inspiration for drawing space...
download and unzip example file (CR2 M070). Then open drawing, set MYPAR value to negative one and update sheet. You will see the following note.
MH
Martin Hanák
Very elegant solution MartinHanak
Thanks to learn me something new...
