Using Creo Distributed Batch to batch export DXF
PL_14410747
I'm using Creo Distributed Batch to batch export DXF, but I found this tool will divide drawing sheet to single DXF file, how can I to export them as 1 DXF file ?
My CREO version is 8.0.3.0
5 REPLIES 5
does this mean that you have Creo multisheet drawing?
Martin Hanák
Hi Martin
Yes, that's correct, one drawing with multisheet
Peter
@PL_14410747 wrote:
Hi Martin
Peter
Are you able to export Creo multisheet drawing from a regular Creo session?
If the answer is NO, then you can't expect Creo Distributed Batch to be able to do it.
Suggestion: Open Case at PTC Support to ask PTC directly.
Martin Hanák
Thanks Matin
Will follow your suggestion to open a case with PTC
Peter
@PL_14410747 wrote:
Thanks Matin
Peter
I asked Google ... creo export multisheet drawing to dxf file
The answer told me that it is possible to export Creo multisheet drawing from a regular Creo session.
https://www.youtube.com/watch?v=tbxPjqKBqss
So if Creo Distributed Batch cannot do the same, then the only option left is to use a trail file for batch generation.
Martin Hanák
This Creo Parametric tutorial shows how to export a DXF (Drawing Exchange Format) file to open a drawing in AutoCAD. For more information, visit https://www.mcaeconsulting.com. If you learned something from this video, please give it a thumbs up. If you like this video, please click the Subscribe
