Does anyone know what the syntax is for placing an assembly component in Creo using Sigmaxim Smart Assembly?
Hi BB_10651838,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
I have used GID to attach the information.
Did you solve this yet because I am having a similar issue?
No, it did not. After getting a call into Sigmaxim, they took me in a different path. I am far from being an expert on this but, what are you trying to do?
