Using Ghostscript to Convert PS to PDF
dgschaefer
Creo 2, M230 on Windows 7, 64 bit
This is slightly off topic as it's mainly a Ghostscript question, but it's related to generating PDFs from Creo and I know that many here use Ghostscript.
At my former job I had used Distiller to create PDFs from PS output from Creo.  It worked well and bypassed the many issues I saw with the built-in PDF creation in Creo.  I'd like to do the same here, but we do not have Distiller available to all users.  I was looking at using Ghostscript, specifically the ps2pdf utility as a Distiller replacement, but I'm having no luck with it.  Unfortunately, the learning curve for GS is rather steep.
I've run the 64 bit GS installer and added a couple of install folders to my path statement and ps2pdf runs without error (I'm using the syntax "path/to/ps2pdf inout.ps output.pdf") but produces no output.
Anyone have an idea what I'm missing to get this running?
Alternatively, anyone have a free or cheap means of scripting the conversion of a PS file to PDF like Distiller?
LinkedIn
in the past (ProE 2001 or older) I used these files...
ps_pdf.pcf ... this means printer configuration file
plotter POSTSCRIPT
button_name PDF
plot_destination file_and_printer default
plotter_command CMD /C c:\bin\tisk_PDF.bat
tisk_PDF.bat ... called from printer configuration file
set PATH=%PATH%;C:\usr\Ghostscript\gs8.51\bin;C:\usr\Ghostscript\gs8.51\lib
call ps2pdf.bat %1
del %1
MH
Martin Hanák
2 REPLIES 2
plotter POSTSCRIPT
button_name PDF
call ps2pdf.bat %1
del %1
MH
Martin Hanák
I was assuming that I could hit ps2pdf.cmd directly by simply using "ps2pdf".  Changing it to use the batch file using "call ps2pdf.bat" fixed it.
Thanks!
LinkedIn
