i have a question about custom symbol. is it possible to have a single variable text repeated?
for instance, i have to use a text in both italian and english language but i have to use the same variable text
ex. ZINC PLATE \ZINC\ AND ZINCATURA \ZINC\
Thanks!
Hi Tom...
I just did the same test and had no problems whatsoever.
Here's the symbol in the symbol editor...
Here's the symbol on the sheet...
Here's the entire set of Drawing Parameters...
This is Creo 2.0 M080 which, I think we all can agree, is a terrible build code to use... but this is what I used for this demo. ![]()
Thanks!
-Brian
Try it and see, the best way to learn
I have the same question, I tried a lot of time and I found no solution.
I opened a call, I give you the answer if I have one!
You can type whatever you want if you use this syntax in a symbol definition
Define the symbol and add \ in front and back of the note
For example
\Zinc\
When you place the symbol in the drawing you ll see only Zinc.
But you can edit these how much time you want in the drawing and you can place it how much times you want
Hope i gave what you need!
If not please more specific what you need
I give you an example of symbol below.
The first line is in Portuguese and the second in English but "codigo" has to be the same value (1 attribute)
In symbol definition I wrote :
But in that case I have to enter a value for each attribute and potentially I will have a different value.
Thanks for your answers. ![]()
I dunno whether this is the answer but lets try
you can use parameters right? parameters in dwg
only thing is to you have to designate it and you are good to go... you can use it wherever you want... just one time edit you ll get the value changed wherever you want
thats all... you ll have to use this parameter in the note wherever you want like this
&PARAMETER_1
Applying it to your case
DEMAIS DIM. VER PECA ESPELHADA: &PARAMETER_1
FOR MORE DIM. SEE MIRROR PA RT: &PARAMETER_1
Hope this solves..
It helps for single drawings,
Thank you,
That doesn't look like an answer to the question about a custom symbol. It does apply to a drawing note. I don't think it is required to designate the parameter as designating is a function for Windchill to see the parameter when it is checked in. If the parameter is not already managed in Windchill it generates an error message, but otherwise succeeds.
Unless symbol functions have changed, they don't allow repeated text variables. It would have to be \zinc1\ and \zinc2\.
It may be possible to assign the same parameter to each symbol variable.
Marked the post as answered considering the reply from Vincent and assuming that it was resolved. Removing Answered. My mistake, overlooked that post was from Christian not from Vincent.
Christian,
When creating a symbol you can add parameter (¶meter_name) as variable value for variable text to call the value of parameter from part. This will call the value of parameter from part in symbol e.g. if parameter in part is material with value as zinc, symbol will call zinc from part parameter.
If you will define the variable text in symbol without parameter, it will independent for both of the in symbol for input.
Hello
I opened a call by PTC and that's the answer :
Désolé, je dois vous communiquer que cette fonctionnalité n’existe pas en Creo Parametric
In English : Sorry, I have to answer that this fonctionality is not existing in CREO Parametric.
Hi Vincent...
This is not an answer, is it? "Sorry, I have to answer that this functionality is not existing in CREO Parametric." Of course not!
There's no way to make this point without sounding snarky. I've been trying for 10 minutes already. So I'm just going to go ahead and be honest. With the utmost respect, most PTC Technical Support personnel are not experts in Creo software. At best, they are well-trained technicians who search for your problem in a large database. If they're any good, they might even recall some nuances of the software which make it easier for them to perform the same search later. However, when they hit a wall that says "Creo cannot perform this function", they stop.
There are exceptionally few tech support specialists who understand the software to a depth where they will fight for a solution to your problem. If the mighty database says it can't be done, then it can't be done. Period. My favorite thing about PTC Community is solving the unsolvable. Few things give me as much pleasure as posting an answer to a problem PTC deemed impossible.
Here's what you need to do - utilize rarely used features intended for cabling inside of SYMBOLS to solve your problem. Various people have suggested parameters (drawing parameters, model parameters, etc). Someone else mentioned it might be possible to use multiple pieces of variable text but that this will require changing each piece of text individually. There's actually a better way!
Inside Symbols you can set Parameters. These were intended to support cabling/component parameters but you can "steal" them for your own purposes if you wish. Everyone knows how to use variable text in symbols with the backslash technique like this: \Variable_Text\ but there's an alternative! You can simply use a parameter stored in the symbol. For this example, we're going to steal the DESCRIPTION parameter from the cabling parameter table and repurpose it. You can actually invent your own parameter, too. It's not really necessary to use the cabling parameters but we'll stick with repurposing one of them for this example:
Edit your symbol definition and follow these steps - click the images for a larger, more readable slide:
If you don't like the standard &DESCRIPTION parameter, you can skip choosing a parameter from the Edit-->Choose Keywords menu in step 1. You can open the Pro/TABLE and type any parameter you wish into the table. Provide the parameter name in the left column and a default value in the right column. Be sure to use your new parameter with the &<new parameter> format in your note and everything will work perfectly. As an example, here's an example of adding a parameter called "NEW_PARAMETER" to the parameters table:
The lesson learned here? Do not believe everything PTC Tech Support tells you. If they've told you "it can't be done", come to PTC Community before you throw in the towel.
Take care and best regards,
-Brian
ok Brian, it works but i've another problem to solve...
if i want to choose a limited number of values, as i can use with ATTRIBUTES, is it possible?
Hi Christian...
It seems as though there are a constellation of possibilities with parameters within symbols. I'm not sure any of them will be precisely what you want. I'm not even sure I can detail all of them succinctly without another set of intricate powerpoint slides but I'll try:
Each use of ¶meter is tied to the current drawing parameter value. If you change one, all of them change simultaneously
To mix and match parameters and restricted values:
I realize this is probably not what you were after - but I was pleasantly surprised at the number of options you can come up with by mixing and matching options. You can also set a drawing parameter and add that to your restricted values list. This allows you to simultaneously reference all of the following:
I hope that helps... I'm not sure if I've confused the situation more than clarified it though!
-Brian
, It seems that appreciation has not been expressed in proportion to your contribution to this thread. Thanks for taking the time to display and explain these features!
I do have a question about one of the methods that you stated. When using the "Drawing Parameter (Tools-->Parameters)" I do not see a way to define the dwg parameter in the dwg and then call it from within the symbol. I tried the methods that you and others mentioned and could not get it to work. For example, if I want to call the PDMLink Attribute "Name", &Name does not work. I also tried it with a company defined attribute, and that also did not work. Any incites for me?
Thanks again! Lawrence
Hi Lawrence...
So let me make sure I understand... you want a specific PDMLink attribute, like &PTC_WM_LIFECYCLE_STATE (which shows something akin to "Release Level" for your file) and you cannot get this to work?
In the examples I gave, I created those parameters in the drawing and then called them in the symbol. I'm having a bit of a problem understanding exactly what's not working for you. If you can give me a picture or a slightly more detailed description, I'm happy to help!
-Brian
Brian Martin, I just did a quick test with an empty drawing and new symbol. I created a single parameter in the drawing (no model present) and then attempted to create a symbol that references it. No matter what syntax I used (¶m, ¶m:d, param:d, etc.), the symbol would not display the drawing parameter value. Not during symbol creation and not after symbol placement. Creating a note in the drawing works fine. This is with Creo 3.0 M050.
Hi Tom...
Thanks!
-Brian
thanks Brian, it works very good also on Creo 2.0 M140
Based on the original text above, I didn't think it needed the "\ \" around it since it wasn't going to be changeable in the symbol. I didn't have anything on the symbol's var text page, I was simply typing the text into the note in the symbol.
So I went ahead and tested again. Here's what I have now:
The problem I'm running into is that the symbol will not automatically update it's value when the drawing parameter changes. The only way to get them to update is either redefine the symbol itself or manually open and close the properties for each symbol individually.
When you change the drawing parameter's value, do all instances of the symbol immediately update?
Thanks.
, thank you for the serious of screenshots and more detailed explanation! I now got it to work and it works as you said.
, thanks for chiming in! I was somewhat at a loss as to where to start on where I was lost and how to include sensible screenshots and your experience/question matched mine. As to getting the parameter to update, try update sheets. That worked for me. The longer method of saving, erasing, and re-opening also gets it to update.
Hi, Brian
How do you edit in the "Var Text" tab the "my_text" attribute: duplicate it, delete it rearrange in case of more than one "my_text"? only by managing the graphic area? If I make another circle (just to have something and write again "\my_text\", I suppose in the "Var Text" tab I will have two times "my_text", right?
Do you have experience with grouping?
Thank you,
nic.
Hi Christian...
Please take a look at the solution I posted and let us know if this helps you!
-Brian
Brian and all,
thanks for your answer, i will check them asap..
i'm a little busy right now, maybe tonight (in Italy...) i will see if one of your answers are applicable to our problem.
thanks in advance
Hi All,
Thank you, that's a good solution Brian for my application.
Thanks and best regards,
Vincent
Just oher idea:
What about symbol grouping?
Source file is attached.
Hope it can helps someone.
Regards
Milan
Hello @mbonka, how are you?
I would like to create a grouping of symbols for text. If you have a tutorial on how to create these groups, it would help me a lot.
