I need to know all settings for sucessfull set for use a Creo license via VPN, in diferrent networks. My license server in my company is available from network (if i need), I have public ip adress, safety set for this time, but nor problem to allow what i need.
Please, I need summary and correct information, ideal step by step, what I set all to use creo license in other network, for my external colleagues,...atc.
Thank you for all info. Richard from company KORIMO, s.r.o.
solution of your problem is probably related to VPN software you are using. In the past IT of our customer did following steps.
Suggestion: Ask Slovak PTC VAR for support.
MH
Thank you Martin, it works. Tested with Creo 4.0 F000 and Flexera V11.
