Hi All
when i create a simplified rep within an assembly, i can use this one on a drawing view.
problem there is, that when i hide something in the assembly, the simplified rep is updated automatically and the views on the drawings too.
is there a possibility to stop this behavior?
BR
I've done it but using a different simplified rep for each step. Then you control what components are shown in each step.
No, not with simplified reps. If you remove a component from a simplified rep and that rep is used in a drawing, it will update in the drawing view.
is there another possibility to create "locked" views in assembly for drawings?
we used to do that to create step by step assembly drawings.
