Viewing Plane Lines - How to Thicken?
ThoRig
Community,
Is there a way to thicken the viewing plane lines in Creo 6?  The first snippet below is from ASME Y14.2, and I know that Creo can make the first two viewing plane lines, but I have not found a way to thicken them.  There is an option cutting_line_segment_thickness, but only for ends and corners, but I couldn't even get that to work.  Thanks in advance.
TomU
(To:ThoRig)
Line thickness is usually handled by pen table files.  These also can apply to PDF output and publishing.
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Ffundamentals%2Ffund_two_sub%2FTo_Change_Plotting_Pen_Attributes.html%23
ThoRig
(To:TomU)
I only want to thicken the viewing plane lines, not all the lines on the drawing.
ThoRig
(To:TomU)
