Thank you for the quick replies! Given that it worked for both of you I dug into the config files and found the culprit: "save_hidden_items_w_status" was set to "no". Turning it to "yes" solved it.
I thought I had searched pretty in depth through there, but I'm glad I finally found it after struggling for so long. Thanks again!
FYI in Creo 11.0.0.0 I am able to save layer status. Unfortunately I do not have any idea why you cannot do this.
EDIT: I used your test_asm.asm.
I tested on creo 11 on your assy and one of mine and I seems to work as expected on mine.
