your situation is complicated. Therefore you cannot expect to find simple and parametric solution.
Simple solution:
I don't have experience with this, but here is an old thread discussing something similar.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Fill-in-the-void/td-p/22588
You may need to resort to Boolean operations.
Hi Chris
Thanks for your answer! I tried to search in archive before posting, but appearantly not good enough.
Yes seems they concluded with boolean operations, but its not ideal..
I am thinking of testing with creating subassembly with components and using volume parameter from this to withdraw from my liquid volume, but seems to be an inconsistent approach as well.. All components embedded in liqud needs to be in that assembly. Another issue is some parts might be partially embedded in liquid volume and etc..
Hi MartinHanak
Thanks for your assistance and model!
Your solution is solving the problem, but I need to make copy surface from each and every component in the liquid and add the volume to relation?
As it might be a lot of component in the liqiud it seems time consuming and a lot of manual updating..
I was hoping to be able to use some parameters from global interference or something, but it doesn't generate any volume parameter. Only yes/no if collision operation is perfomed.
BR Arild
Simple solution:
