This widget could not be displayed.
WELCOME TO CREO (BROWSER WHEN OPEN CREO)
DB_10253499
7-Bedrock
anyone can tell me how turn off the  "welcome to Creo browser" when Creo 9 is turn on?
I can't find on the config setting
HI, i resolve it.
that impostation is saved in the creo_parametric:customization.ui file and it is saved on exit.
Since my system did not allow me to overwrite it because it was in a common folder for everyone, I had to make a local copy of creo, modify the file and then ask to another user to overwrite it in the common folder.
Thanks for the help.
13 REPLIES 13
BenLoosli
(To:DB_10253499)
Right there on the image.
That box in the lower left corner, check it and the welcome screen will no longer be displayed.
Hi, yes that I know thanks. But everyday my sistem erase everything and make a new one system. The only things it keep is config end costumization
There isn't a flag somewhere in config to click?
BenLoosli
(To:DB_10253499)
The system is resetting too many files as that button click is stored in one of the customization files.
Why are you resetting the full system every day?
I run a batch file for launching Creo and only overwrite a group-wide config.pro. I leave the other files alone so the users can do their own thing, if they want to.
hi,
because where i work everybody need to have the same configuration so you can change local but the day after you have the same of everybody
thanks
I find the browser to be annoying. I suppose it's useful for maybe people with WIndchill(?) but I don't need a browser in my CAD software, I already have a browser, thank you very much.
I have the following settings in my config.pro to stop these shenanigans:
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab        no
enable_resource_browser_tab     no
web_browser_homepage            about:blank
Perhaps these will help you, too.
kdirth
(To:KenFarley)
I also have config:
enable_punditas_browser_tab no
KenFarley
(To:kdirth)
I am adding the punditas one in immediately. I thought I was stuck with that always coming. Gotta be more thorough when I'm scanning the config options, I guess.
I wil try thanks I hope to resolve
NOT WORK
the 1°,2°,4° i have the same. The 3° can't find
UI modifications are saved in following file
%AppData%\PTC\ProENGINEER\Wild{re\.wf\.Settings\creo_parametric_customization.ui
  • start Creo
  • modify UI
  • copy the file on safe place
    • I guess it would be necessary to copy whole %AppData%\PTC directory
Next day
  • copy PTC directory backup to %AppData% directory
  • start Creo
Martin Hanák
I have already try to export creo_parametric_customization.ui after flag the icon
but nothing change
HI, i resolve it.
