I need to create a list similar to the BOM but with the asm welds. I need the weld information (SEQ_ID, TYPE) and I need the welding process intervals linked to that weld. I have some parameters in the weld process but i dont know how acess this parameters in the drw. I add some photos.
Using the example of the photos iset the weld process 3, in the weld process have parameters about current, tension and gas. So i need a table like this:
SEQ_ID TYPE WELD_PROCESS CURRET(A) TENSION(V) GAS
1 FILLET PROG3 230 26 CO2
2 FILLET PROG2 210 22 ATAL25
I am using CREO 8. Thanks!!
