We ran into that problem with M040 and M100 WF4. Check to see if the correct check files are even being used.My condition filehad "If clause" for MODELNAME EQ VL-8* *with asterisks) combined with GROUPNAME. ModelCheck would NOT use the check, start and condition files in the "If clause". I had to delete those statements and create a .bat file for our Librarian Groupto use a different set of ModelCheck files/location. PTC was able to duplicate the problem and the fix is expected in build M160. By the way, in M100, you can add the ModelCheck directory to your config.pro.
