WF5 decimal places
AdamDorsch
WF5 decimal places
I am working on testing out Wildfire 5 and am running into a weird issue.
I have a part modeled at 8.126 long, I change the decimal properties to a two place dimension, the dimension shows as 8.13 on the screen, the drawing shows 8.13 but it still measures out at 8.126 and shows 8.126 in the Dimension Properties window.
What am I missing??? Why doesn't the part change to be 8.13 long?
WF5 M060
Thanks in advance
Adam M Dorsch
CAD Supervisor
Alliance Laundry System LLC
Shepard Street P.O. Box 990
Ripon, WI 54971-0990
ph (920) 748-4554
fx (920) 748-4301
http://www.comlaundry.com/
I seem to remember that the default handling of rounding changed in WF5.
A rounded driving dimension used to do as you describe, change the size
of the part. Now by default it does not. I think there's a config
option for it, but I don't know what it is.
Doug Schaefer
LinkedIn
round_displayed_dim_values
No - newly created or first shown
dimension is displayed with all its
significant decimals."Rounded Dimension
Value" Check Box will be unchecked while
opening Dimension Properties Dialog.
Yes - number of decimals is rounded according
to default dec places option."Rounded
Dimension Value" Check Box will be
checked while opening Dimension
Properties Dialog.
Tracy Willis
