Warnings for Varied Items in Assy
wfalco
All,
Looking to clean up some warnings in an assembly lots have worked on.
A part was assembled as a varied item (flexible). Looks like it's done legitimately?
I get the warning below when opening assembly. Anyone know why?
Creo4-m020
WayneF
9 REPLIES 9
TomU
(To:wfalco)
The resolution is not terribly helpful, but this KB article seems to match what you're experiencing:
https://www.ptc.com/en/support/article?n=CS133724
TomU
(To:wfalco)
Similar article for later versions of Creo:
https://www.ptc.com/en/support/article?n=CS104016
wfalco
(To:TomU)
I guess this was not resolved?
  • Reported to R&D as SPR 2825095
  • Works to product specification for Pro/ENGINEER and Creo Elements/Pro
  • Remove the Varied Items and redefine it
  • Under consideration by Product line management
TomU
(To:wfalco)
Apparently not.  If you look at the corresponding SPR, it gives a little more info:
TomU
(To:TomU)
... and based on the fact that it's been open since 2007, I wouldn't hold out hope it will ever be fixed.
wfalco
(To:TomU)
Yeah - I was not sure if it was complaining cause it was locked or something else. I attempted to unlock. Can't find anything. I think I read to uninstall and re-install? Have not tried that. I may try.
Thanks Tom! I will give you the resolve in a few days if no one else answers. Feel free to nudge me.
TomU
(To:wfalco)
No, I don't think this has anything to do with uninstalling and reinstalling, I take it to mean you just need to remove the flexibility from this dimension and then make it flexible again.
DPeters01
8-Gravel
(To:TomU)
Yes
wfalco
(To:TomU)
Yes undo and redo.
I did one. So far it appears to be working. Looks likes others in the assembly.
