Hi, I have attached my part in this discussion and I was wondering is there anything I can change to model the wave spring so it doesn't touch each other as I have problem trying to mesh and analyse it then. I have used equation and relations in order to model this part. In addition to that, is there anyway that I can model it as an interlaced wave spring with the same relations? Thanks! The part attached can't be simulated later on as there are meshing problem which I'm not sure how to fix as well. Any help would be great! Attached in the images are the relations that I used and the part I'm trying to model. Is there any possible way I could change the relations so that the part doesn't intersect or interpenetrate each other? Thanks! ![]()
