Web Intralink Authentication
ptc-601014
Newbie
Hi all,
We're putting together a web application that allows the user to enter their Pro/Intralink login and password. Then, in the background, we authenticate the user. Has anybody done that? If so, do you have any advise or recommendations on the best way to do it?
Terisa
1 REPLY 1
Re: Web Intralink Authentication
There are a couple of ways that you might do this, but it depends
on what functionality the web application is using:
1. Intralink Scripting application (Java)
2. Intralink Toolkit application (C/C++)
3. Oracle SQL application
4. Use LDAP or Active Directory instead
If your application is essentially one or more Intralink Scripting
(or Intralink Toolkit) applications, then you can just try to run
it with the given login and password. If they are correct, the app
runs. In this case you're not really doing any authentication, but
rather passing the responsibility to Intralink.
If you're running SQl queries, then you wouldn't want to startup
the client with every request. An Intralink based application
method would be pretty slow if used like that, but it could work.
Another way, would be to create a web services front end controlling
a persistently running Intralink session that validates passwords.
It would do nothing more than to login/logout and indicate if a
password was valid. If the client was already running, then this
would be pretty fast, but problematic if multiple users are hitting
the site at the same time.
Looking in the Oracle tables directly would be great, but the
passwords are "encrypted" either as MD5 checksums or using Oracle's
Ofuscation Toolkit (or something similar). Unless you can figure
out which method was used, this isn't going to work.
If the OS user IDs are the same as the Intralink user IDs, then #4
could be the less problematic solution. More companies have done
this to authenticate users on a internal websites, than try to
authenticate against Intralink passwords. As a result you will find
more help on this method than any other. If you're trying to do
something with an Intralink client session, this won't work at all.
Marc
