Hello All,
I have been using Creo 10 for about a year now with a SpaceMouse Enterprise. Recently, when I have an assembly open (doesn't happen in individual part files), I get the regular red "diamond" that shows me the spin center when moving the model with the SM, but I also get an additional red "dot" now that I have not seen before. Additionally, when I let go of the SM to stop moving the model, it then shifts in a random direction, sometimes up to 1/5 of the screen, away from where I moved it to....
I think that second red dot is linked to the weird shift as I had not had the shifting issue before this dot appeared.
How do I make it go away?
Updates:
- The red dot only appears when rotating with SM. When rotating with MMB, I get no red dot, but the model shift is still there. It is actually more severe when using MMB, causing the model to shift out of frame.
- Closing the model, and re-opening seems to have "fixed" the shifting issue, but red dot still visible.
Hello @Noah10267,
Thank you for using PTC Community.
Your question has not received a response so far.
In order to receive meaningful responses from other community members, could you please provide more details and context regarding your inquiry?
You can add information like:
This will enhance the likelihood of receiving valuable assistance from other Community members.
You might also find it useful to refer to this informative video on how to ask a good question.
I hope this information is helpful.
Best Regards,
Vivek N
Community Moderation Team.
