Weld Symbol that was edited, reverts back randomly.
RH_9684496
I am using the weld application to generate welds and symbols for my drawing.  I am having an issue where I turn some things off for a weld symbol to hide certain aspects of the symbol and then they randomly change back to default showing everything.  I am using the Symbol Customization function in Creo 9.0 to modify the symbol.  Anyone ever encounter this and if so, is there a fix?
Ryan
Same issue, very annoying. No idea what's causing it or what's the fix.
Will open and work on the same model drawing in the same way multiple times and have no issues, open it six months later for a different change and have to basically redo all of the weld notes.
