Weld UI Standard
fred_roy
Weld UI Standard
Hi everyone,
WF5.0 M040.
We have an issue here where we want to change the standard used for welding from ISO to ANSI. Help tells us that switching it in Tools/Welds/Preferences should fix the issue, but it doesn't work. It seems like whatever standard the assembly was started with cannot be changed.
Any suggestions?
Fred
Hi everyone,
Found it... sorry to bug you all for nothing. While in Welding Mode, go to File/Weld Standards. The pop-up menu allows you to switch from one to the other.
That was almost too easy.
Fred
