Weld showing in a simple rep, yet the parts are 'excluded'...
pshepherdson
Hi all,
OK, so I have a simplified rep, and I now have some welds showing.  (Floating in space)..  The parts these welds are attached to are both 'excluded' from my simplified rep, and 'quilts' are turned off.  Yet they now appear in my dwg / dwg view.  And I can't seem to turn them off..
The welds were added after the simplified rep was created, and also after we upgraded to Creo 9 (from Creo 3, not sure if that has anything to do with it..)
But I have a dwg of some panels & their associated screws, and now I have some beefy welds floating around in the views..
Any ideas on how to remove them (and not do the 'erase line by line')
9 REPLIES 9
mkajdan
(To:pshepherdson)
You can use Component Display in the Layout tab to blank them from the individual views, the entire sheet or the entire drawing.
yeah..  no.  if it was a part or some other "feature" I could.  But welds aren't controlled this way...
The welds should follow the parts they are attached to, and should follow if those parts are removed [excluded] from the simple rep.  in my case, they don't..  Hiding quilts also doesn't 'turn them off' ..
mkajdan
(To:pshepherdson)
One caveat, the technique of blanking them only works if they are solid welds and not surface welds.
please ask PTC Support.
Martin Hanák
thanks for the suggestion,  when thru the various steps to log an issue thru 'PTC Support', and got stopped as they need some SCN number..  No idea what this is, nor where to get it..  so, no ticket produced..  (And 15 minutes wasted..)
You can find SCN in license file in Contract column
Martin Hanák
kdirth
20-Turquoise
(To:pshepherdson)
File > Help > About Creo Parametric - Service Contract Number (SCN)
thanks!!
(Ya figured they coulda put that in the little '?' they offer...)
I had a similar problem after a Creo Version upgrade. All my welds are placed on separate layers. Although I hid this layer in my drawing the welds were still showing in the views.
As it turned out, I did not only have to hide the layer in the drawing but I also had to hide all welds individually that where on that layer (expand the layer in the layer tree and select all welds with shift+LMB).
But this was only for .asm after the Creo upgrade. When creating everything in the new Creo Version I did not encounter that problem anymore.
