Hi..
Please can anybody suggest that what are the activity needs to do for upgrading creo3.0 from creo2.0.
Is it need to save every drawing format, drawing templates, start part template, asm template, tables in creo3.0 or as it is also OK ?
Above things are working if we use it as it is, so what is the best practice to upgrade ?
Prashant Pandarkar
Creo 2 files will load fine in Creo 3. You shouldn't need to recreate or resave any of them. The only things you may need to adjust are ribbon customizations, mapkeys, and config options. Most of these will probably be fine, but it's good to test.
OK thanks for the information.
Will try to use as it is.
Prashant Pandarkar
