What happened in Creo 4 M010 drawings when you need to adjust the distance of the lines in the cut?
pnos
What happened in Creo 4 M010 artwork when it is necessary to set the spacing of lines in the choice of cut in gray always worked not now hatch.jpg
dschenken
(To:pnos)
Did you try "Scale"?
There's a new Xhatch method available in Creo 4 that uses complex methods for which Spacing may not apply; I'm guessing that's this case because Scale would not apply to algorithmically generated lines.
rohit_rajan
(To:pnos)
...we still have this kind of menu in Creo 4.0.......
