What happened in Creo 4 M010 artwork when it is necessary to set the spacing of lines in the choice of cut in gray always worked not now
Did you try "Scale"?
There's a new Xhatch method available in Creo 4 that uses complex methods for which Spacing may not apply; I'm guessing that's this case because Scale would not apply to algorithmically generated lines.
...we still have this kind of menu in Creo 4.0.......
maybe you should try smartxhatch
SMARTXHatch 8.0 for Creo parametric 2.0 - Handle Hatchings with ease! - YouTube
