What happened in Creo 4 M010 artwork when it is necessary to set the spacing of lines in the choice of cut in gray always worked not now ![]()
Did you try "Scale"?
There's a new Xhatch method available in Creo 4 that uses complex methods for which Spacing may not apply; I'm guessing that's this case because Scale would not apply to algorithmically generated lines.
...we still have this kind of menu in Creo 4.0.......
maybe you should try smartxhatch ![]()
SMARTXHatch 8.0 for Creo parametric 2.0 - Handle Hatchings with ease! - YouTube
