What is API to visit Piping objects [Pobjects]? , There are action functions for visit
jpatel
There are action functions for visit & filter for Piping objects [Pobjects] but seems main visit function is missing. Can anyone help me to confirm on this?
2 REPLIES 2
pwilliams-3
(To:jpatel)
To be clear, there are visit, filter and action functions for pipeline members, network extensions, and objects of pipeline series.  I would highly recommend reading the API Wizard under User's Guide->Production Applications: Piping->Piping Terminology.  There is a great explanation of each object type within.
To acquire a handle to one of the various objects (there is no specific object type for this, it's a ProFeature) I would start with the following:
1. Use ProSolidFeatVisit to visit all objects of type PRO_FEAT_PIPE_* by filtering in the filter function.  Read ProFeattype.h for all applicable types.  I found the following possibilities.
#define PRO_FEAT_PIPE 945
#define PRO_FEAT_PIPE_SET_START 1020
#define PRO_FEAT_PIPE_PNT_PNT 1021
#define PRO_FEAT_PIPE_EXT 1022
#define PRO_FEAT_PIPE_TRIM 1023
#define PRO_FEAT_PIPE_FOLL 1024
#define PRO_FEAT_PIPE_JOIN 1025
#define PRO_FEAT_PIPE_LINE 1027
#define PRO_FEAT_SLD_PIPE 1029
#define PRO_FEAT_PIPE_JOINT 1032
#define PRO_FEAT_PIPE_BRANCH 1033
2. Then in the action function use the appropriate ProP* function on the ProFeature object to get the data of interest.  For example to get the pipeline network I would use ProPipelineNetworkEval(p_feat, &pro_pNetwork);
Hope it helps!
Thanks for you support WIlliams
Actually I was having this info. while raising this question. I was bit suspicious about Pobject Visit API, because actions APIs are evidence to have it.
Thanks again.
