What is the exactly behavior of the config option: "system_window_run_in_background"
Feb 26, 2021
02:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Feb 26, 2021
02:20 AM
I am using Creo Parametric 6.0 6.0.5.1
Feb 26, 2021
09:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Feb 26, 2021
09:05 AM
according to https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Ffundamentals%2Ffund_one_sub%2Ffundamentals_configuration_options.html page:
no*, yes
Sets the system window to block Parametric or to run in the background.
System window is Command Prompt window started from Creo environment.
Martin Hanák
Feb 26, 2021
10:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Feb 26, 2021
10:31 AM
Config option "system_window_run_in_background" is to block or Unblock Creo Parametric when system window is active.
When a user enables system window (Command Prompt/DOS Window) for any operation e.g. Purge, Creo Parametric Window deactivates for user. When the config option is set to yes, Creo Parametric will not deactivate for user, it will allow user to work in Creo Parametric without closing the System Window.
I hope this will help.
Thanks.
EDIT: Check images for clarification.
