What would cause the session ID to be lost
SYNDAKIT
Problem:
          In assembly relations a dimension session ID is lost/changed.
Information:
          The error given in the message line is "Line 819 assembly RAKE_BEAM: Symbol 'D0:14826' not found."
          The error given in the relation editor is "Invalid symbol 'D0:14826' found.
          For example D0:124=length:199  will change to  D0:14826=length:199
          The part that the relation is referring to is suppressed by pro/program.
          I can fix this by opening and regenerating the suppressed part. Then when I go back to the assembly the relations are fine.
          This is not happening to any other suppressed parts within that same assembly.
What do think is going on here?
SYNDAKIT
(To:SYNDAKIT)
It was an external reference issue. It looks like re-constraining the part worked......for now. (dun dun duuuunnnnn)
