Problem:
In assembly relations a dimension session ID is lost/changed.
Information:
The error given in the message line is "Line 819 assembly RAKE_BEAM: Symbol 'D0:14826' not found."
The error given in the relation editor is "Invalid symbol 'D0:14826' found.
For example D0:124=length:199 will change to D0:14826=length:199
The part that the relation is referring to is suppressed by pro/program.
I can fix this by opening and regenerating the suppressed part. Then when I go back to the assembly the relations are fine.
This is not happening to any other suppressed parts within that same assembly.
What do think is going on here?
It was an external reference issue. It looks like re-constraining the part worked......for now. (dun dun duuuunnnnn)
