I am using Creo Parametric Release 5.0 and Datecode5.0.6.0
A critical error was encountered. Traceback written to D:\00AkimConfig_prowildfire20130323\traceback.log Please send it to technical support.
Here are the errors that I faced:
Translated by Simona Cuciureanu on 12th April 2022 using Google Translate
遇到到严重错误。已将回溯写入 D:\00AkimConfig_prowildfire20130323\traceback.log 请将其发送给技术支持。
Dear Partner ,
I propose you to open a case to PTC technical support for this issue in order to investigate further.
Best regards
Jean Claude
Dear customer,
Thank you for posting your request regarding the premature exit of Creo 5.0 with traceback.log file.
In order to check this tracebac.log file I need your company customer number .
I tried to identify your company as CADVIP but I do not succeed.
Please can you give me your customer number?
thanks in advance
Jean-Claude
Dear Partner ,
Best regards
Jean Claude
