When I am adding screws automatically through IFX, the generated bolt nut is having interferences becuase bolt is modelled on major dia and nut is modelled on minor dia. I have an assemblies where I have more than thousand parts including screws and nuts. When I am adding screws through IFX and doing global interference check, the result is always filled with screw interferences, therefore it is difficult to identify real intereferences. Why dont PTC make the library model nut part with hole major dia and put the cosmetic thread as internal minor dia. I think in this method there would not be any interferences in library part.
Hi Jayanta,
thank you for mooving your idea IFX screw fasteners to the IFX Group.
I have added you idea to this group: Avoid interference for IFX fasteners.
Lets see what other users say.
Hi Jayanta,
by the way - of course it is possible to modify the part like you want.
Just open the template and redefine the fastener. If you need assistance in customizing parts I can send you a user guide for this.
PTC will also upload a movie and/or a document about customizing IFX parts to the help center soon.
