When you save a backup of the assembly, you want to save all parts and drawings
QL_7456004
当您保存装配体的备份时,您希望保存所有零件和工程图
Translated by the moderation using Google Translate
When you save a backup of an assembly, you want to save all parts and drawings
Hi @QL_7456004
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
requested functionality is not implemented in Creo Parametric (without a connection to Windchill).
Martin Hanák
StephenW
(To:QL_7456004)
This is part of Windchill PDMLink functionailtiy
BenLoosli
(To:QL_7456004)
Saving a backup of the drawing will save the assemblies and parts.
The assembly and parts have no linkage to the drawing, except with Windchill.
Dale_Rosema
(To:QL_7456004)
If you do not have Windchill, you can see the work around I posted in this thread:
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-make-copy-of-PART-amp-DRAWING/m-p/392873
It's sort of slow and tedious, but hey, it works.
