Where can I find the tutorial for Import Data Doctor in Creo2?
ropitz
...or download a pdf like in previous versions of Pro/Engineer...
5 REPLIES 5
MartinHanak
(To:ropitz)
Hi, thank you for this hint. I know this manual and I know it from Pro/E 2001. I hoped to find any to understand the updated menus in Creo2. But I think the one of Creo 1 could help. So thanks a lot.
Rudi
Attached is the one I have for Creo 1.  I haven't seen one for Creo 2 yet.
Bill
Hi Bill,
in earlier versions of Pro/E there was installed always the import data doctor with the pdf manual. Now in Creo 2 it is missing. But the menu was significantly updated to common Creo2 UI. I think your attached manual will help me. I had a quick look to it and I know those models used for these exercises. They are prepared pretty well for the exercises and everything works in a nice flow :-).
Thank you very much, I think that's it!
Best regards, Rudi
mbonka
(To:ropitz)
Hello RUEDIGER OPITZ‌,
se link below:
Re: Import Data Doctor (IDD) for Creo Parametric
Hope it helps.
Regards Milan
