Where/what is the default pen lneweight settings when saving to a pdf without using a pentable?
BriGuy
11-Garnet
I'm reconfiguring our practice of saving a drawing as a pdf.  I've set up a pentable which seems to be working ok.  I'd like to be able to see what the lineweight settings are for the pens when not using a pentable.  Is there a location or option for this in Creo 2.0?  I see that the config options for the pens (ex: pen1_line_weight) refers to an electrostatic plotter, which I take to be our ink plotter.  The only options I see and am using that refer to pdfs are pen_table_file and pdf_use_pentable.
MartinHanak
(To:BriGuy)
@BriGuy wrote:
Is the idea of this to create a .plt file? If so, we have printer options which can create a .plt file.  I can also create a .ps file.  Either way, neither type of files give me any information regarding PW commands.
yes when I create plt file, I can read line widths in it.
How to ...
1.] open drawing
2.] File > Print
3.] open plot file in Notepad++
original file
%0BBPINCR;NP;WU0;SP1;LA1,1,2,5;IP-680,-199,11200,8200SC;PA;LT;LT;PW0.508
PC1,0,0,0;LT;UL6,60.0,40.0LT6,1.8,1;PW0.254PC1,0,0,0;PUPA3320,4200PDPA
5320,4200LT;PW0.127PC1,0,0,0;PUPA3320,4600PDPA5320,4600PW0.508PC1,0,0,0;PUPA
3320,3800PDPA5320,3800RO;IW;SP0;PG;
modified file
PW0.254PC1,0,0,0;PUPA3320,4200PDPA5320,4200LT; ... hidden color ... 0.254 mm
PW0.127PC1,0,0,0;PUPA3320,4600PDPA5320,4600 ... letter color ... 0.127 mm
PW0.508PC1,0,0,0;PUPA3320,3800PDPA5320,3800 ... geometry color ... 0.508 mm
RO;IW;SP0;PG;
Martin Hanák
10 REPLIES 10
MartinHanak
(To:BriGuy)
Thanks Martin.  Yeah, I've looked at those already.  Just can't find what Creo has for a default value for the pens when not using a pen table.
MartinHanak
(To:BriGuy)
if you are interested in finding default pen widths then I suggest you following procedure:
  • set DESIGNJET plotter as output device
  • export drawing into plot file
  • open plot file in Notepad
  • look for PW commands (eg. PW.025 means 0.25 mm width)
Martin Hanák
MartinHanak
(To:BriGuy)
How to ...
1.] open drawing
2.] File > Print
original file
modified file
RO;IW;SP0;PG;
Martin Hanák
Thanks Martin.  This got it to work for me.
TomU
(To:BriGuy)
Probably not super precise, but measuring a PDF containing lines of each pen type shows three line widths in use:
  • 0.125 mm (.005 in)
  • 0.375 mm (.015 in)
  • 0.500 mm (.020 in)
See attached PDF.
Note:
  • This PDF was created with Creo Parametric 6.0
  • Even though the PDF refers to 8 pens, the config option 'use_8_plotter_pens' was set to 'no' when this PDF was created.
BriGuy
11-Garnet
(To:TomU)
A couple of questions.  How did you create this pdf?? Also, do you have a pen table assigned or is pdf_use_pentable set to No.
TomU
(To:BriGuy)
I have a format built with all this stuff on it for testing pen table settings.  When generating this PDF no pen table was used or present and 'pdf_use_pentable' was set to 'no'.
TomU
(To:BriGuy)
I did some more testing.  Here is what I'm seeing in Creo Parametric 6.0:
  • If line width is set to zero (default), then pen table values will be used.
  • If no pen table is present, Creo default values will be used.
Default Pen Table Values (inches)
Default Pen Assignments
Note:  The use of 4 or 8 pens is controlled by the config option use_8_plotter_pens.
