Which enhancements of Creo 4.0 do you like best?
lbai
I think Creo 4.0 is a very classic big release than Creo 3.0, the following enhancements are I like top ten:
  • Box- selection - available in part mode and assembly, very convenient and effective
  • New Mini Toolbar- Direct command access from Mini Toolbar and dual context support
  • Flexible modeling extension added into sheetmetal and simulate
  • Sketch snapping to model entities- without explicit projection
  • Style G3 (Acceleration) Connections
  • Assembly new Booleans - Many to many
  • 3D Sweep
  • Mid-plane
  • Full screen
  • File names Support for double-byte characters
You can review full list from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS236243
Other good news, refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS251133, Creo 4.0 M010 will support AR and Creo 4.0 M020 will support IOT
7 REPLIES 7
James62
(To:lbai)
Does filenaming in Creo Parametric 4.0 allow for longer names than 31 characters? Does it allow spaces, forward slashes, dots and other sorts of chars?
I guess I should just install it and try it out.
dschenken
(To:James62)
The better question is: does Windchill x support these characters in names?
Good question. I imagine Windchill will require upgrade.
James62
(To:James62)
Ok so, it works as in previous releases, that is 31 chars limit and only dashes and underscores are allowed.
whu-2
(To:lbai)
I just like geometry search tool in flexible modeling, set line thickness in sketch, new material library including about 100 material and new cross-section hatch library
gzhou-2
2-Guest
(To:lbai)
just like the 3D Sweep. but need to half year for Creo 4.0 M020
udyna
(To:lbai)
The following new is very good, also wait for many many year ago
  • file name support Chinese
  • Datum Feature Symbol
  • mid-plane
  • full screen
