I think Creo 4.0 is a very classic big release than Creo 3.0, the following enhancements are I like top ten:
You can review full list from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS236243
Other good news, refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS251133, Creo 4.0 M010 will support AR and Creo 4.0 M020 will support IOT
Does filenaming in Creo Parametric 4.0 allow for longer names than 31 characters? Does it allow spaces, forward slashes, dots and other sorts of chars?
I guess I should just install it and try it out.
The better question is: does Windchill x support these characters in names?
Good question. I imagine Windchill will require upgrade.
Ok so, it works as in previous releases, that is 31 chars limit and only dashes and underscores are allowed.
I just like geometry search tool in flexible modeling, set line thickness in sketch, new material library including about 100 material and new cross-section hatch library
just like the 3D Sweep. but need to half year for Creo 4.0 M020
The following new is very good, also wait for many many year ago
