We have been running W4.0 for a couple months now and for the most part we
like it. We work with a lot of imported surfaces and the new Remove
function is great! The import data doctor has been improved. Surfacing
seems to be more stable. We have an issue with scaling parts sometimes
and I haven't quite figured it out yet as to the cause, it is rather
intermittent. The navigation has changed to some apparent
Vista-bread-crumb-thing-wonderful-idea. No real advantage there that I
can see. Shaded views in drawings and the 3d pdf export is pretty cool. I
have trouble with people getting freaked out with edrawings and the whole
shade and spin thing so I'm not sure the 3d pdf is going to go over right
away.
We jumped from W2 to W4 since I didn't see any real advantage to other
moving to W3. The only issue I had with loading W4 was that you need to
get a new license pack for it to work.
All in all I think it is a good move
Kim
To
cc
Subject
[proecad] - Who's onWF4?
Like it/hate it? I SHOULD have mine up and running this afternoon after
dealiong with the usual NightmareLink issues. Opinions?
Thanks!
Well, as much of a complete pain as I've personally had with our "upgrade" to NightmareLink, it's good to hear that WF4 is an improvement. The autoround looks interesting, but as always with rounds, we'll see about the robustness of the algorithyms when it comes to difficult intersections. I noted that the demo was pretty simple. I, honestly liked the ability to use both new and old-style rounds in the last version before WF (200I2?). Whatever it was, the surfacing commands before WF were far more robust, especially in surfs by boundary, which is almost completely useless now as I always get an error sayint that the boundaries don't form a closed loop.....when I know damn well they DO. So, if they've fixed that to be as robust as it USED to be, pre-WF, great. Also, I noticed the "curve thru intersection of 2 sketches" has some really weird results in WF3 as opposed to previous versions. As I do a lot of trajectories like that, that completely sucks. Now, if they'd only get rid of the confusing WF interface and go back to the way it was, and especially dump the "lead vs. follow workflow" garbage where you never know whether to pick "action/object" or "object/action"..........Argh!
Thanks for the info guys, keep it coming!
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
Dr. Seuss
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
