Why the Mapkeys can't work in the 2D model
bduncan
hi,I have creat a mapkey in the 3D model,but when I work in the 2D model,the mapkeys do not work,
4 REPLIES 4
StephenW
23-Emerald II
(To:bduncan)
They should work if the selections are the same.
It would help to find the problem if you include what you are doing with the mapkey and maybe include the text of the mapkey.
In the 3D model,add the below relation,and make two mapkes,one to control “NO”,another to control “YES”,then saving into the config.pro。Then go into the 2D model,but the mapkeys don't work.。See the video
if ZY==NO
STAGE_MARKERS_A='Trial'
STAGE_MARKERS_B=''
ENDIF
if ZY==YES
STAGE_MARKERS_A=''
STAGE_MARKERS_B='Positive'
ENDIF
tbraxton
22-Sapphire I
(To:bduncan)
As @StephenW has noted, you have not provided enough information to enable a meaningful reply. Your description of 2D model is ambiguous, are you referring to sketch mode or drawing mode with a reference to 2D model?
Multi-mode mapkeys are not straightforward to create. Are you attempting to use a mapkey created in part mode in drawing mode as well? If so, then you would need to create a multi-mode mapkey by recording the commands in both modes and then using a nested mapkey to call/execute both sets of commands.
Involute Development, LLC
Consulting Engineers
if ZY==NO
STAGE_MARKERS_B=''
ENDIF
if ZY==YES
STAGE_MARKERS_A=''
ENDIF
