How to get to system stop doing this? See image
https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/fundamentals/fundamentals/fundamentals_configuration_options.html page contains following information
try changing the regen_solid_before_save option value in the config to something other than the default
I think Yes should be it? Correct?
Hi
I like your answer. "Try it and see" 👍
*force is it! Thank you.
