Why the annoying window of regeneration pops up every time I save
Yogesh.T
How to get to system stop doing this? See image
https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/fundamentals/fundamentals/fundamentals_configuration_options.html page contains following information
regen_solid_before_save
prompt*, force, yes, no
Controls the regeneration of the model
prompt*—Displays the Conflicts dialog box. The Conflicts dialog box informs you that the model is not regenerated.
force—Regenerates all the features.
yes—Regenerates the unregenerated features.
no—Does not regenerate the features.
Martin Hanák
6 REPLIES 6
Van_AG
(To:Yogesh.T)
try changing the regen_solid_before_save option value in the config to something other than the default
Martin Hanák
Yogesh.T
(To:MartinHanak)
I think Yes should be it? Correct?
try it and you will see ...
Martin Hanák
Yogesh.T
(To:MartinHanak)
Hi
I like your answer. "Try it and see" 👍
Yogesh.T
(To:MartinHanak)
*force is it! Thank you.
