Windchill Parameters showing up on save
fred_roy
Hi everyone,
I've wasted enough time on this... I need your help.
I've added the &ptc_wm_modified_bySmiley Very Happy call-up on our drawing template so
that when a user modifies the drawing, his/her username shows up.
The problem is this; on my station, when I save, the parameter
(PTC.WM.MODIFIED.BY) fills up on a save (which is fine). On others',
they have to upload for that parameter to fill up, which is kind of a
pain in the behind...
Any ideas what setting would drive that?
Jean-Frederic Roy, M.Eng
Sr. Mechanical Designer
SPIELO, A GTECH Company
tel: 506.862.1460
fax: 506.852.7640
- <">mailto:->
www.gtech.com <">http://www.gtech.com>
CONFIDENTIALITY NOTICE: The contents of this email are confidential
and for the exclusive use of the intended recipient. If you receive this
email in error, please delete it from your system immediately and
notify us either by email, telephone or fax. You should not copy,
forward, or otherwise disclose the content of the email.
Hi Ben,
The only two options I can find that relate to something similar are
