We just loaded Creo 2, M090 and now the windows (the play path, parameters, etc) pop up directly in the center of the screen. I know that there is an easy fix, but can't remember going through it when we loaded M030. This should be an easy one for someone to answer, right?
Thanks.
This was resolved with some tweeks to the video card settings.
Hi Matt
while I don't have an answer to your question, I have a question regarding windows...and the latest build..
Have they fixed it in M090 so the window don't go and hide behind the screen, especailly if you have play path open, and also want to open tool info window, when you select play path, the info window goes behind creo, if so I will upgrade to M090.
been a problem since WF5.
would be good if this is fixed.
peter
Peter,
Please step me through an example of your issue, and I will let you know what happens in M090. I'm not sure about which window is hiding on you or how you are using tool info and play path at the same time.
I've been told that my initial issue is related to the video card and not PTC.
Matt
