I like the new (well, it's been a few years now) tools for Project and Offset. They're harder to teach, but they're more robust. But today I tried to use a seldom used command: Convert to Tapered. It used to be you can select an Offset geometry in the Sketcher and hit Operations->Convert to->Tapered, and then have the offset vary from one end to the other. Nice little trick.
Well, it seems it doesn't work anymore? I tried getting it to work, but it's always greyed out. I searched through the documentation, and found this little note:
There is a hidden configuration option available to use the legacy offset functions in sketcher. Add this line to your config.pro file to use the old offset functionality. Note that you will need to set this option to "NO" in order to invoke the new version in the same session of Creo if this config option is loaded as set to "YES".
SKETCHER_USE_CREO8_PROJ_OFFSET YES
Thanks, what a classic!
"How do I do X in Creo?"
"Well, first you need to go into the config and activate this secret command ..."
It's not the first time. 😀
EDIT: Seems like it's a deprecated option, meaning to use it I'd have to get permission from PTC. I guess the Convert to Tapered function should be considered lost for all practical purposes. A pity! Not sure if there is a good workaround?
There is a reason that the config option is a hidden one. There has been a lot of user pushback on PTC regarding the new sketcher offset functionality and the inability to deal with scenarios where the old version simply works or works better. Credit is due to PTC for creating this config option after deploying the new functionality so that users can revert to the previous implementation.
Wait, does this mean if I set this option I will be able to offset lines and arcs, as a chain, instead of having to do much more extra geometry creation? That would be really nice. When we switched to Creo 9 from 4, the first time I experience this "de-hancement", it triggered a lengthy diatribe on here (by me). It was a big boot to the neck, to be sure.
With the option set to yes, the UI /functionality reverts to the Creo 8 version of the offset tools.
There are some inconveniences of the newer Offset and Project tool, to be sure, but overall I think it’s an improvement, as it enables the user to use smart chain selection techniques to create more robust references rather than referencing each curve individually. It would have been even nicer with a toggle button to choose whether to offset as a chain or as individual entities, especially since some functionality was lost (like the Convert to tapered operation).
