I have a dimension where one witness line was dragged from it original location. Is there a way to "reset" where this belongs?
(WF5.0/Creo)
Thanks, Dale
Dale,
As there is no option to rest, you may try moving such diemnsions to any another view and back to original view.
I was hoping for something like insert jog/remove jog. No luck.
Dale,
Try this:
Select dimension + View (Using CTRL) > Drag the handle of witness line.
Are you talking manually adjusting the end of the witness line? Is so, yes I know about this. I was wanting to know if there was a way to reset it to it's default location as determined by the dim gap in the config.pro so that if I use in a family of parts it will default to the gap dimension versus the placed position which doesn't update with new instances.
Thanks, Dale
